using ferrite core
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Sep 19, 2012.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    why we can not use the ferrite core as a choke
    thanks
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can.
    A "choke" is an inductor having a relatively high impedance, used to prevent the passage of high frequencies.
    If you salvage components from discarded electronic equipment like satellite television tuners, you may find that internally, the AC power wires are wrapped several times around a toroid. The toroid will have a high Al value to keep high frequencies from passing along the wire; resisting both ingress (incoming RF signals) and egress (outgoing RF signals).
    TAKYMOUNIR likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Have a look in the following PDF:
    rf_proto-1.pdf
    From page 8 and on there is a description of the RF chokes.
    Bertus
