The Idea to use solenoid valve coils is good, but I have already bought the magnets and am making the valve bodies to suit, but if I find the magnets do not work it will not be to difficult to modify the valve mechanism just by extending the steel rod to pass through the coil, I should have done more research before starting, but I just wanted to get going.
The matter of the encoder being incremental not absolute, I had not realized there are different types. If I use an an opto-switch or some other sensing device to determine TDC will I need one for each cylinder or can the other five be calculated from the one position, probably a stupid question but I have not much of a clue beyond simple electrics.
