using circuit maker to draw a resistor at 45 degrees
Discussion in 'General Electronics Chat' started by ndshelp, Oct 6, 2011.
  1. ndshelp
    Oct 6, 2011
    5
    This is my first post I think. I tried to post a new thread and got 2 errors
    so I am sorry if it is posted twice. My ? is can you draw a resistor or wire
    at 45 degrees like in a bridge circuit using CIRCUIT MAKER.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Sorry, the answer is "No" to both questions.
  3. ndshelp
    Oct 6, 2011
    5
    thanks for your reply
  4. nigelwright7557
    May 10, 2008
    488
    71
    You could make up a new component(s) with the pads at 45 degrees to each other ?
  5. ndshelp
    Oct 6, 2011
    5
    I just started using CIRCUIT MAKER so I will have to read about making
    a new part. Can you recommend another free electronics simulator that can
    draw resistors at a 45 degree angle. Thank you
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    LTSpice is good and free. Google "LTSpice download". It does not have provisions for rotating components at other than 90°, but you can make your own symbols that are rotated. The CircuitMaker user interface kind of spoils you, it's pretty good. The LTSpice user interface is a bit quirky; it just takes some time to get used to it.
    CircuitMaker is no longer supported, so it's pretty much a dead end.
  7. ndshelp
    Oct 6, 2011
    5
    thanks again
  8. CraigHB
    Member
    Aug 12, 2011
    127
    15
    I think LTSpice is great even without considering it's free. I've used a few other non-free simulators and I still like LTSpice better.
    It certainly is quirky, but the interface is designed for simulation, not drawing circuits. Once you get used to it, you find it draws circuits well enough and the way it handles those mousey clicks is superior for simulation.
    Like SgtWookie said, you can make your own symbols and there's no limitation there. Though, I don't see why it would matter unless you're looking to produce an image of a schematic. In that case, you would not want to use a SPICE program for that.
