Hi guys,
First, thanks for any help you can give. This is really appreciated.
I am trying to use an automatic car aerial to create a gadget where a sign will rise when a button is pushed. I have the footswitch and the aerial but I am having trouble getting the aerial to work. Details of the aerial can be found here:
http://www.maplin.co.uk/module.aspx?TabID=1&criteria=usb&ModuleNo=5141&C=SO&U=Strat15
what I really need to know is:
a) What powersource can I use and can I avoid having to buy a full car battery?
b) should this be as simple as rigging the green wire to the negative and the red to the positive via a switch and fuse, or am I missing something
Thanks again for any help you can give. I look forward to hearing your replies
