.equ sk, p1.0 ;serial clock
.equ di, p1.1 ;data input
.equ do, p1.2 ;data output
.equ cs, p1.3 ;chip select
;__________________________________________
Mov SCON, #50H ;serial mode
Mov TMOD, #20H ;timer1 mode2
;Read a byte from EEPROM
Read: SETB cs ;cs is set
LCALL Clock
SETB di ;di is set
LCALL Clock
MOV A, EEADR
ANL A, #3Fh
ORL A, EEBYT ;code and address for read
LCALL wr_byt ;send address
LCALL Time
LCALL rd_byt ;read a byte
CLR cs ;cs is set
RET ;return
;___________________________________________
;Write byte to EEPROM
Write: SETB cs ;cs is set
LCALL Clock
SETB di ;di is set
LCALL Clock
MOV A, #30h
LCALL wr_byt
CLR di ;clear di
CLR cs ;clear cs
LCALL Time
SETB cs ;cs is set
LCALL Clock
SETB di ;di is set
LCALL Clock
MOV A, EEADR
ANL A, #1Fh
ORL A, #40h
LCALL wr_byt
MOV A, EEBYT
LCALL wr_byt
CLR di ;clear di
CLR cs ;clear cs
LCALL Time
SETB cs ;cs is set
JNB do, $
CLR cs ;clear cs
LCALL Time
SETB cs ;cs is set
LCALL Clock
SETB di ;di is set
LCALL Clock
MOV A, #00h
LCALL wr_byt
CLR di ;clear di
CLR cs ;clear cs
RET ;return
;____________________________________________________________
;Clock time delay
Clock: SETB sk ;clock is set
MOV R6, #10h ;move 10 hex into reg 6
H_Loop: NOP
NOP
NOP
NOP
DJNZ R6, H_Loop
CLR sk ;clear clock
L_Loop: NOP
NOP
NOP
NOP
DJNZ R6, L_Loop
RET ;return
Time: Mov R6,#10H
by Robert Keim
by Don Wilcher
by Duane Benson
by Jake Hertz
