using an 18f2431
Discussion in 'Embedded Systems and Microcontrollers' started by robertpeach, Aug 21, 2009.
  1. robertpeach
    Aug 21, 2009
    hi, im not sure if many of you will have used the 18f2431, but there is a chance you might have.
    ive been programming my 2431 in picbasicpro, however ive come to a point where i need to use assembly language instead of BASIC language. this is easily integratable into my code. however im not used to the language at all.
    i need my pic to use its motionfeedback module, to measure 3 inputs. im measuring the period of 3 phases, each being measured on the cap1, cap2 and cap3 respectively. relating to porta.2 porta.3 and porta.4 respecitively.
    from the datasheets i need
    cap1m0 = 0101 ; cap1 measures period
    cap1ren = 1 ; cap1 resets timer after timing
    cap2m0 = 0101
    cap2ren = 1
    cap3m0 = 0101
    cap3ren = 1
    does anyone know how to code what ive described at all? i havnt the faintest clue on assembly even from looking at tutorials and examples...
    thanks for any help you can provide :)
  2. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    I am not familiar with picbasicpro but am not sure that you need to use asm. What lead you to that conclusion?
