using AD8221 with single supply
Discussion in 'General Electronics Chat' started by legolas11, May 27, 2014.
  1. legolas11
    Feb 26, 2013
    55
    The data sheet of AD8221 says it can be used both as a single and dual supply, however when i try with single supply (12 V ) to amplify a 100 mv signal (gain=1) the output is oscillating. with a dual supply (using voltage divider) it's working fine...
    Can anyone suggest me an In-Amp that can be used with single suupply....
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Can you post your schematic?
    Bertus
  3. legolas11
    Feb 26, 2013
    55
    the circuit only contains low pass filter at the inputs of in-amp...
