Using AC rated switches on DC
Discussion in 'General Electronics Chat' started by electricnewb, Nov 10, 2013.
  1. electricnewb
    Nov 9, 2013
    7
    I have a 12v DC load (probably more like 14v on a fully charged car battery) and my max circuit will be around 15 amps. Can I use an AC rated switch to power this load and if so what ratings do I need to be looking for on the switch? Specifically I am looking at AC rated wind up timer switches.
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    technically NO..
    DC is harder to switch and as such requires better contact design/materials,etc... Buy a dC rated switch..
  3. #12
    Nov 30, 2010
    16,704
    7,354
  4. nsaspook
    Aug 27, 2009
    3,016
    2,375
    An AC only rated switch won't work very long as the contacts will arc badly when opened on a inductive load. At 15A even on a resistive load it would fail quickly. I would use the AC switch to power a 12vdc auto relay. A 30 to 40 amp relay is only a few dollars.
    #12 likes this.
  5. #12
    Nov 30, 2010
    16,704
    7,354
    That's a way! Use the timer to control a DC relay which uses only a little current for its coil.
  6. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    A good source of DC relays is if you have an auto wrecker near you, you can usually get a handful of relays for a couple of $.
    Look for the larger ones not the mini relay size, there are usually two sized used in a modern auto.
    The one near me you can remove the whole relay centre complete with fuses for $5.00!
    Max.
  7. ErnieM
    Apr 24, 2011
    7,440
    1,627
    A good source of DC relays is EBay, where they come with sockets pre-wired with 6 inch colored wires. Dirt cheap if you have a few weeks for the free shipping to work.
  8. electricnewb
    Nov 9, 2013
    7
    So if I understand correctly there will still be DC running through the switch that will in turn be switching the DC relay but the switch will be fine since he load being switched at that point will be very nominal (just the coil from the relay) Do I understand that correctly?
  9. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    Correct, the switch will just operate on a few Ma.
    Incidentally I don't think you mentioned if it was inductive or resistive final load, makes quite a bit of difference.
    Max.
  10. GopherT
    Nov 23, 2012
    6,321
    4,046
    Yes, an AC switch should be fine to control a few milliamperes of a relay coil.
    The relay is designed to switch high DC currents.
  11. electricnewb
    Nov 9, 2013
    7
    It is a resistive load in this case (lights)
    Thanks all. The relay approach will work perfectly!
  12. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    Resistive load? you probably would have got away with just the switch!
    Max.
  13. #12
    Nov 30, 2010
    16,704
    7,354
    I don't think so. "Lights" probably means tungsten.
    The links I provided specifically down-rate the timer to 7 amps for tungsten compared to 20 amps resistive.
  14. nsaspook
    Aug 27, 2009
    3,016
    2,375
    It might work for a while but the internal mechanics of a AC switch will cause the contacts to pit and develop high resistance causing heating if there is a large on-rush current. A true DC switch is designed to wipe while quickly snapping from a contact landing zone to a contact parking zone to keep the internal resistance low. A regular AC switch just does a slow make or break on one spot.
    #12 likes this.
  15. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    IMO Very little difference for most switches out there switching a DC resistive load.
    Max.
