Using a wall mounter dimmer to drive a bigger load than it is rated for
Discussion in 'The Projects Forum' started by garch, Feb 3, 2010.
  1. garch
    Aug 23, 2008
    24
    I have existing wall mounted (no neutral) triac dimmers. They can drive up to 300W (@ 230VAC). I would like to use them to drive a much larger resistive load. I have enclosed a circuit diagram that uses the 300W dimmers as a driver for a seperate TRIAC with a higher power rating.
    Would this work?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    probably not! The original dimmer needs a minimum load that is much lower than 2K.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Get a approved dimmer that can handle more current. Tampering with such equipment is not recommended.
  4. garch
    Aug 23, 2008
    24
    Getting an approved dimmer is not an option. These are ACT EU frequency zwave dimmers. They only come in one rating. I have ten in my house and they cost 80 dollars a piece.
    Hence my question.
  5. garch
    Aug 23, 2008
    24
    Updated diagram enclosed. Replaced 2K load resistor with 2 x 1K, 50W (in parallel) resistor load.
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    Many restaurants are throwing away high power dimmers because they are switching to efficient compact fluorescent light bulbs that cannot be dimmed.
    If you still heat your home with wasteful incandescent bulbs then pickup a powerful dimmer from a restaurant.
  7. garch
    Aug 23, 2008
    24
    Thanks,
    But I say again, these are ZWave dimmers that I already have and are integrated into the house automation system.
    Net net they save power because:
    1) They are auomatically dimmed to match ambient light levels (by the computer)
    2) The lights turn off when you leave the room
    3) Part of the lighting array uses proper "dimmable" cfl's anyway where possible, with a resistive load (mains halogens) included to allow the TRIAC to operate.
    4.) Part of the lighting array uses German made ultra high efficiency fluorescent linears (A+ rated) that are dimmed via an intelligent dimmable ballast.
    I did the Carbon Calcs for my home and this method is more efficient than replacing every light with a simple CFL. Turning CFLs on and off continually is not very efficient.
    and before you ask...
    The automation computer is totally solid-state and purpose built and uses very little power. It uses about 30W of power at full gallop.
    I want to up-rate the dimmers driving capacity to increase their reliability. The triacs seem to fatigue after about one year, so wanted to implement a master-slave config to buffer them. It is what microwave oven designers do to increase the reliability of the driver triacs that modulate the massive inductor that drives the magnatron.
    p.s. I did do a BSc (hons) in Electrical Enginnering 20 years ago, but am a little rusty on the power electronics side.
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    You have dimmers all over your place.
  9. garch
    Aug 23, 2008
    24
    Yes, 20 dimming modules in total.
