You are not required to run them at the recommended brightness. if they are brighter at 20 mA they will be a suitable brightness at perhaps 2 mA as opposed to 5 or 10 mA with a less efficient LED.Kim, I'm in Texas, US. I was indeed thinking of getting one of those hot air guns for heat shrinking, but most I've seen on Amazon were sort of expensive or otherwise I wasn't sure about their quality. Which cheap one do you think is pretty good? Thanks for the LED info.
That Goldmine has quite a few different style LEDs, thanks for mentioning it and Jameco. Since I was looking into atmospheric glow and low light "soft white" or "warm white" LEDs would be best, but not all brands/resellers seem to have them. Goldmine does have some, but most of them are already quite bright to begin with. The Chanzon ones I found on Amazon do have lower output so they may be better for what I'll use them for.
One option would be to cut out the individual LEDs from LED strips as I've seen some do, but I was thinking I may stay away from that because I would like the LEDs to be exchangeable more easily, in case they burn out.
I think I'm about ready to order some stuff and once that gets in I'm going to have to experiment I haven't started yet but this seems fun already. The one thing I wasn't sure about was power supplies. I am going to experiment with 5v phone chargers but thought I might get a Bench Power Supply too, but I don't know if it is very useful to get a cheaper one (like around $60 range).
Re: Power supply
Work with the power supply you will use in the application.
I use "wall wart" (phone chargers and such) power supplies for all my projects. I have been collecting them for years from yard sales and second hand stores. I usually pay less than a dollar for them. I do not own a bench grade power supply. What ever I need I can find something among my stock.
