Using a switch to disable speakers/drivers??
Discussion in 'General Electronics Chat' started by Soogs, Jun 9, 2016.
  1. Soogs
    Jun 7, 2016
    8
    Hi all,
    i recently put together a mini bluetooth speaker using the TDA7492P module.
    the issue im having is that when powered on the circuit makes a stupidly loud startup sound.
    i believe the amp switches on at about 70% power and its way too loud when others are sleeping in the house, or even in the garden etc
    is it ok to put a switch inline with each of the speakers to kill that initial start up sound?
    will a switch deteriorate the sound quality?
    Many thanks in advance!
    Soogs
  2. AMenard
    Jun 7, 2016
    11
    It would be better to just put a protection circuit or a delayed action relay like most modern receiver have.
  3. hrs
    Member
    Jun 13, 2014
    86
    7
    The datasheet says the chip has a mute function. Might be worth trying that.
  4. Soogs
    Jun 7, 2016
    8
    Amended - would you mind giving an example of such things? (I'm a noob)
    Hrs - there are 2 versions of this unit... Unless I'm missing something.
    The one I have doesn't have a power switch or line in/out. It's just a bt receiver and 2x 50 amp.
    I'll have a look at the data sheet when I get back indoors.
    Thank you both for your suggestions =)
    Soogs
  5. AMenard
    Jun 7, 2016
    11
    http://sound.westhost.com/project33.htm
