Using a switch to clock digital circuit
Discussion in 'Homework Help' started by colincraig1, Nov 5, 2005.
  1. colincraig1
    Nov 5, 2005
    Help needed urgently!!
    Briefly discuss the effect of using a switch to clock a digital circuit & sketch a circuit diagram to overcome this problem
    Discuss the key characteristics of the 7476 & 74hct112 logic families
  2. Dheejay
    Nov 6, 2006
    exact same question, help needed. seen u couldnt help this person back in 2005 surely someone can help now!
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You'll need a debounce citcuit to use the switch and get a good clock. An R-S latch works very well for that. Look at a 74xx279 for the function, anthough a pair of NAND gates will work as well.
    You will find a lot of difference between original TTL and CMOS HCT logic. Datasheets should explicitly spell out those differences.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Motorola makes a Switch Debounce IC part number MC14490. It is actually capable of debouncing 6 switch with the single IC.
    hgmjr
  5. robinboss
    Jul 22, 2005
    What is debouncing?
  6. JoeJester
    Apr 26, 2005
    3,387
    1,211
