Using a push to break switch to turn something on
Discussion in 'The Projects Forum' started by Tickers, Jul 5, 2011.
  1. Tickers
    Dec 24, 2009
    17
    I have a component with about 10mm of travel, and I need to activate a lamp as soon as the component travels at all.
    The only suitable switch I could find was a push to break plunger switch, how can I use the PTB switch to get a voltage across the lamp?
  2. KMoffett
    Dec 19, 2007
    2,586
    234
    What kind of lamp? Lamp voltage/current?
    Ken
  3. Tickers
    Dec 24, 2009
    17
    It's an array of LEDs, at around 5V and 1A.
  4. CDRIVE
    Jul 1, 2008
    2,223
    99
    Way too vague. Does this have to latch? If so, you need a way to unlatch. This can be done using the same switch if triggering a bistable flip flop.
  5. KMoffett
    Dec 19, 2007
    2,586
    234
    Echo CDrive. Can you give us the big picture...what you're trying to do with what. It's often easier to help solve your problem than help solve your solution. ;)
    Ken
  6. strantor
    Oct 3, 2010
    4,302
    1,989
    I would try using your normally closed switch the same way a NPN transistor is used in open collector output configurations, with the output going to a NPN transistor to switch your LEDs
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I think I'd use a logic level N-ch MOSFET instead of a transistor. With 1A current required, you'd need 100mA base current to saturate a bjt (bipolar junction transistor), and that represents a substantial "tax". A Darlington would have a Vce of 0.7v or more, so that's out as well.
    Have a look at the attached schematic.
    The MOSFET could be an IRLD024, which comes in a 4-pin DIP package - nice for breadboarding; rated for 60v, and up to 2.4A collector current.
  8. strantor
    Oct 3, 2010
    4,302
    1,989
    I guess the time has come for me to get with the program. This is the 3rd or 4th time I have played the transistor card, only to be immediately trumped by the MOSFET card.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, power MOSFETs have come so far in the last 20 years or so that they're mighty hard to ignore. Their biggest downfall is their sensitivity to static electricity, but once they're in a circuit, they're pretty darn rugged.
    strantor likes this.
  10. castley
    Member
    Jul 17, 2011
    31
    If you want to keep it simple. Use the push to break switch to short out the lamp with a resistor in series with the lamp.However, the lamp would go out again as soon as the switch goes closed again. Is this what u want?
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The LEDs use 1A current. If they're using a constant current source, then the switch would be sinking a constant 1A current; if the LEDs were using simple resistors, then the sink current could be considerably more than that.
    The MOSFET switch idea I submitted is pretty simple, and would only have a drain of 0.5mA when the switch is closed. That's a pretty significant savings in power.
