Using a Pot as a Variable Resistor
Discussion in 'General Electronics Chat' started by tracecom, Jun 27, 2010.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,879
    1,396
    When using a potentiometer as a variable resistor (i.e., using the wiper and only one other terminal), is it proper to tie the unused terminal back to the wiper? Does it matter? Why?
    Thanks.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You don't have to do this, but wipers sometimes don't make contact. Tying the unused side down offers some failure protection if this happens.
  3. tracecom
    Apr 16, 2010
    3,879
    1,396
    That makes sense. Thanks.
  4. sceadwian
    Jun 1, 2009
    499
    37
    Tieing one end to the wiper also helps distribute the current across the entire POT element. It's not perfect, but it will give you slightly higher power handling than otherwise.
