Using a PIC as a complete SMPS
Discussion in 'The Projects Forum' started by THE_RB, Jan 12, 2010.
  1. THE_RB
    Thread Starter AAC Fanatic!
    Feb 11, 2008
    5,435
    1,305
    Hi, I was playing with the idea of using a PIC as a complete SMPS, so all it needs is an inductor and a couple of caps.
    The PIC's push-pull FET outputs work fine as a buck converter with synchronous rectification.
    I tried using a cheap 8-pin PIC as a Buck SMPS LED driver, that seemed to work ok, and also another circuit as a 5v to 3.3v Buck SMPS "regulator";
    The results and schematics can be seen here;
    PIC-smps projects
  2. S_lannan
    Jun 20, 2007
    247
    good read.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    I just noticed that on your site in the last couple of days. Pretty nifty, Roman ;)
    Hadn't had time to comment on it before; too many other projects on the stove at the moment....
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Thanks guys, I thought someone would like it. :)
