Using a metal desk
Discussion in 'General Electronics Chat' started by magnet18, Jan 16, 2011.
  1. magnet18
    Thread Starter Senior Member
    Dec 22, 2010
    1,232
    125
    Hi, im using a stainless steel desk as a workbench, should i have my desk grounded (im guessing yes), how should i go about grounding it, and if i ground it would it be usable as a ground when prototyping circuits or will there be too much interference picked up by it (large flat surface, laptop sitting on it...)?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Did you read the link I gave you? It pretty much explains everything you need to know.
    ElectroStatic Discharge
    magnet18 likes this.
  3. magnet18
    Dec 22, 2010
    1,232
    125
    Oh, sorry Bill, i actually didn't see that, my bad.
    Yea, that pretty much answers my questions, thank you! :)
  4. kubeek
    Sep 20, 2005
    4,686
    805
    I really wouldn´t use a steel desk, becase you will most probably short out every PCB you work on. You would probably have to add some kind of plastic cover, they even make special ones for working with ESD sensitive devices, but they are quite costly.
  5. Kermit2
    Feb 5, 2010
    3,838
    961
    Go to a home improvment, or lumber store, and by a panel of pressboard.
    It's the thin hard stuff that looks like glue stiffened cardboard. Its a decent insulator and its CHEAP.
    I have used it for wall panels behind my equipment, and every couple of years I pull it off, trash it, and put up a new panel. ($8 US)
    They also make a version with holes in it you can put pegs in it and hang tools on it.
  6. spinnaker
    Oct 29, 2009
    5,062
    1,160
    I think the OP is looking for ESD protection.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    From my ESD article...
  8. PatM
    Dec 31, 2010
    81
    72
    Check this link:
    http://www.allaboutcircuits.com/vol_6/chpt_1/2.html
    Look at the paragraph entitled Work Area.
