Using a Junebug to program another microcontroller
Discussion in 'Embedded Systems and Microcontrollers' started by Micro9000, Dec 18, 2009.
  1. Micro9000
    Sep 22, 2009
    Hey guys, it has been a few weeks, but I have some time off now that classes are over. I've started to try and program my microcontroller using the Junebug which I have purchased. I have the PIC18F4685, and I was wondering how I go about programming it through the Junebug.
    I have built and compiled a successful program for the Junebug where the LEDs flash. In doing so, I have made sure that the link and library paths are correctly linked in build options. Also, I have the necessary header file for the PIC18F1320, which the Junebug uses.
    I have found this C program on a tutorial site to do a simple test. Here is the code I have used:
    Code ( (Unknown Language)):
    1. #pragma config OSC=INTIO2, WDT=OFF, LVP=OFF, DEBUG=ON
    2. #include <p18f1320.h>
    3. #include <delays.h>
    5. void main()
    6. {
    7. ADCON1 = 0x7F; // make RA0 digital
    8. TRISA = 0b10111110;
    9. PORTA = 0b00000001; // Turn LED on
    10. while(1); // loop forever
    11. }
    Now, here is the problem. When I connect the ribbon cable shown here (the second picture towards the bottom):
    I get the following error:
    1. Programming Target (12/18/2009  12:55:25 AM)
    2. PKWarn0003: Unexpected device ID:  Please verify that a PIC18F1320 is correctly installed in the application.  (Expected ID = 0x7C0, ID Read = 0x0)
    3. Erasing Target
    4. Programming Program Memory (0x0 - 0xF7)
    5. Verifying Program Memory (0x0 - 0xF7)
    6. PK2Error0027:  Failed verify (Address = 0x0 - Expected Value 0xEF63 - Value Read 0xFFFF)
    7. PICkit 2 Ready
    (Note: This only occurs when I connect the ribbon cable to the Junebug)
    I realize I am most likely missing a lot of steps and I probably should call to the PIC18F4685
    header file, but I am unsure of what else I could be doing wrong or how to even go about making the Junebug program the other PIC.
    In sum
    What do I need to add to the code (I'm sure it's off by a lot) or modify physically to properly program the PIC18F4685 using the Junebug?
    As always your help is much appreciated. Thanks.
    I do not currently plan to flash LEDs with the other PIC, but if possible, simply read any voltages/square waveforms coming out of one of the pins using my oscilloscope.
  2. THE_RB
    Feb 11, 2008
