using a dpdt to reverse a drill motor
glynn
Joined Jan 30, 2015
9
I have an old black and decker 3/8" drive electric drill. I have a 6 pin dpdt on-of-on switch. How can I use this switch to reverse the drill rotation without flipping the forward/backward lever on the drill?
MikeML
5,444
AFIK, those motors are wound-rotor, wound-stator. Reversing requires flipping either rotor with respect to stator or vice versa...
BillB3857
Joined Feb 28, 2009
2,571
Max, you lost me with the bridge suggestion. Another problem may be that the drill could be variable speed, ie triac control.
MaxHeadRoom
Joined Jul 18, 2013
28,699
As others have said, it is a Universal motor so the field or the armature has to be reversed WRT the other.
If you notice the left hand stator winding goes to the left hand brush, this conductor would have to be cut and each end connected to a conductor to enable the reversing of the field to the rotor.
It may not be worth the hassle.
Max.
