Using a benchtop power supply
Discussion in 'General Electronics Chat' started by Trueblue, Mar 23, 2013.
  1. Trueblue
    Mar 13, 2013
    7
    I recently bought some beginner electronics books, various components, breadboards, multimeter, and a benchtop power supply. I received the power supply and I am not sure if it is working correctly. I turned it on and the voltage knob works as I would expect. When I try to adjust the current knob to set the maximum current, the screen does not change. Does it need to be under a load or something? Thanks to anyone who can enlighten me.
  2. spinnaker
    Oct 29, 2009
    5,102
    1,190
    You need to have a load. Read your manual. It will probably tell you to short the leads, then set the current. Un-short leads after it is set. But read your manual first to verify the procedure.
    Trueblue likes this.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    If you turn the current control to the minimum setting and put something you know would be a heavy load on the output, you will be able to adjust the current. That way, you will be able to protect your projects by limiting the amount of current the supply will be able to provide, while at the same time keeping the voltage output constant. If your project tries to draw more than what you have the supply set for, the output voltage will start to drop off. This is called "foldback" control.
  4. Trueblue
    Mar 13, 2013
    7
    Spinnaker, thanks, I will go try that now. The manual, unfortunately, must have been translated from Chinese into English by someone who does NOT speak English.
    Thanks again...
  5. spinnaker
    Oct 29, 2009
    5,102
    1,190
    What is the model of PS?
  6. Trueblue
    Mar 13, 2013
    7
    Thanks BillB. You and spinnaker helped a lot.
  7. Trueblue
    Mar 13, 2013
    7
    It is an XPOWER model 305D. It is one of those clone power supplies from China. It only cost $62 on Amazon. I figured I would get it to start until I can settle on one that will meet my needs for the "long run".
  8. spinnaker
    Oct 29, 2009
    5,102
    1,190
    I assume this means it is working now? :)
  9. Trueblue
    Mar 13, 2013
    7
    Yes, thank you very much...
