count_volta
- Joined Feb 4, 2009
- 435
I think you could just set the 555 to create a square wave and then feed the output of the 555 into an integrator op amp. That will give you a triangle wave. That is one way we learned in EE school recently.
The dual opamp circuit has one opamp generating a square-wave and the other opamp is the integrator.I think you could just set the 555 to create a square wave and then feed the output of the 555 into an integrator op amp. That will give you a triangle wave.
See post #13.I think you could just set the 555 to create a square wave and then feed the output of the 555 into an integrator op amp. That will give you a triangle wave. That is one way we learned in EE school recently.
I will try these but if I can remember correctly, I already tried those exact values with similar results. I'll try again though.try 10µF or 4.7µF.
Yes I want it to slowly dim and brighten. The led is only a visual test to make sure the varying waveform is working. However, the problem is, the led fades, but never completely extinguishes. I thought this was due to the vertical offset and I was attempting to use a capacitor to bring the offset down so that the waveform could go to zero.The LM324 opamp is low power so its minimum output sink current is only 10mA and if you connect an LED without a current-limiting resistor then the output of the integrator is shorted at a couple of volts (the forward voltage rating of the LED).
Why are you driving the LED through a coupling capacitor that blocks DC?? Don't you want it to slowly dim and brighten when it is driven from the variable-DC triangle waveform?
The output of the LM324 integrator can drive a transistor emitter-follower that feeds an LED that has a series current-limiting resistor.
Of course, because the LED is a diode rectifier which charges the coupling capacitor until it does not have enough voltage anymore to make the LED bright. Get rid of the output coupling capacitor because you want the LED to be driven with the varying DC triangle waveform.when I use a cap, the led pulses, but the pulses get dimmer and dimmer until you can't see them anymore.
I used simple Ohm's Law to calculate the peak voltages of the triangle waveform. Its minimum voltage is 3.25V which is too high to turn off most LEDs (maybe a blue or white LED will turn off).the problem is, the led fades, but never completely extinguishes.
If you decrease the VD voltage and increase the value of the 3.9k resistor then the 3.25V to 6.24V triangle waveform can go from 0.05V to 7.7V.I think I mentioned it before, but I'm trying to build a low frequency oscillator for a simple guitar phaser circuit. I was only using the led for a visual aid. I was under the impression that the LFO output needed to sweep between 0V and +V in order to be effective in the phaser circuit.
I am aware that this post is a major necro-bump.. However, this link is the best guide to the 555 I have ever read. I just registered to say thank you Wendy. I have been using your 555 circuits for some RF applications and they are invaluable.A little acknowledgment is always nice.
by Duane Benson
by Duane Benson
by Aaron Carman
