One last thing to try, if the previous step doesn't work.
In any case it would be nice to learn that the last step in post #40 works but I would still go ahead and add this next step.
Replace the Vcc connection at pin-14 of CD40106 (green jumper) with a resistor, something from 100Ω to 1kΩ. Insert the 0.1μF and 10μF caps at pin-14 to GND.
Rewire the lines from the power supply to the board. Have a separate wire going to this resistor. Add another wire from the power supply to the circuits that power the LEDs.
What driver chips are you using to feed the LEDs? Are the LEDs common-anode or common cathode?
When we do fix the problem I will explain the method in my madness.
