using 74LS123
Discussion in 'General Electronics Chat' started by semi12, May 14, 2007.
  1. semi12
    May 14, 2007
    I'm using the SN74LS123 one-shot to lengthen a pulse. The chip works fine when my input pulse widths are > 500ns. I would like to input a 100ns pulse & have the chip trigger off of it.
    I'm not sure why it doesn't ? I've been trying to find the spec on minimum input pulse width but no luck so far. Does anyone know ?
    Regards,
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    My Motorola Schottky TTL manual does not show a minimum trigger pulse width. Are you sure the pulse meets the TTL logic level requirement?
  3. JoeJester
    Apr 26, 2005
    3,393
    1,211
  4. semi12
    May 14, 2007
    I'm pretty sure the input pulse is TTL-compatible, because I'm using a function generator to supply the input pulse. I setup everything & then start to decrease the pulse width. For example, at 1us it works fine. Finally after stepping down to ~ 400ns, the output is zero (no pulse).
    Attached is the schematic.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    I would suggest you reconfigure your 50K resistor to be a variable resistor and connect it between the R/C pin and Vcc. It will not solve your minimum input pulse width problem but it will make the output pulse width adjustment better.
    hgmjr
  6. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Questions:
    1. Which test results that lead you to believe it's not working as you designed? I mean, within a few nanoseconds after the input pulse, did Q go high or did it remain low? Can you post the pic of your oscilloscope presentation?
    2. What model oscilloscope are you using to assist you with your troubleshooting?
    3. Your delayed output seems abnormally long. Do you need that type of a delay? What is your variable resistor set at?
  7. chesart1
    Jan 23, 2006
    269
  8. semi12
    May 14, 2007
    chesart1 - the 40ns number refers to tw, the output pulse
    hgmjr - he 50K is a pot & is hooked up between R/C & Vcc
    joe - yes, the RC time constant is large - I need an output pulse (Q) of many seconds - & I'm getting it. The problem only happens when I start decreasing the input pulse width. The output pulse simply disappears (the chip no longer reacts to the trigger pulse).
  9. cumesoftware
    Apr 27, 2007
    1,330
    11
    You could try with the 74HC/74HCT logic family. It is even faster than the 74LS family.
