Hi all,
Im new here glad to join you.
Bit of a question.
Im after a transformer to step 240v up to 400v around the 3-4 KVA.
Now saw a 3 phase transformer going for a good price and wondered if i could use it?
It was disighed as 3x 400v in and 3x80 out...
Below is the layout with the way im supposing i can connect it to get the 240v im after. Can this be done?? Would resestances in the secondary windings affect the 240v series output?.. or anything weard that i dont know about? ( Im expecting the three primary winding to be identical and the same with the secondaries... as I would think it be crazy if there was differances between the phases..
Also the original KVA rating is about 3280 KVA. I take it this figger would be total and not per phase?... So connected the way i have showen would be 3280KVA?
Bit of a question.
