I am attempting to reuse the LCD power supply of a dell monitor that I found junked on the street.
The power supply uses a 12-pin cable that has a separation of 2mm.
The standard PCB has a separation of 2.54mm. I know that 1.27mm pin headers have adapters available for 2.54mm spacing (alternate pins are bent).
However, I am stumped as to how a set of headers with 2mm spacing can be put on a PCB. As far as I know, PCBs only come in 2.54mm and 3.96mm spacing.
Perhaps someone may know of a 2mm to 3.96mm pin header (with alternate pins bent) ??
