using 16F877 microcontroller with USB flash memory
Discussion in 'Embedded Systems and Microcontrollers' started by speed1, Apr 27, 2012.
  1. speed1
    Mar 9, 2012
    16
    Hi guys,
    hope it's nice weekend for all.
    I'm working in my project it's about "LCD network cable tester", but I want to add a usb port to be able to connect a flash memory and save the test result in a excel format (.xlsx) or .txt
    is there any idea or info can help ?!
    thank you very much for all your support and help I learned a lot :D
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Your PIC do not have a USB master port. So that is not an easy task. Is this nice to have or need to have in your project?
  3. speed1
    Mar 9, 2012
    16
    it's nice and added feature but not required.
    IS there any idea or advise to add this feature? OR I have to use another PIC
  4. CVMichael
    Aug 3, 2007
    416
    17
    Equivalent of 16F877 but with USB it is PIC18F4550
    All the pins are the same except the ones for USB...
  5. speed1
    Mar 9, 2012
    16
    Thank you CVMichael I'm reading the datasheet for it to know how can i use it.
    thank you again brother.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    But for in order to write a USB memory stick. You must have a PIC that can work as USB master. That will not the latter 18F chip be able to do. As it is only a slave type USB
