using 12V power adapter on a 9V wifi modem?!
Discussion in 'General Electronics Chat' started by rezamoezzi, Dec 28, 2015.
  1. rezamoezzi
    Dec 28, 2015
    I used an 12V adapter for my modem(philips SNB5600) instead of 9 volt.
    It was working but just after 10 seconds it made a noise and It didn't work anymore.
    So I want to ask,what exactly happened and is there any hope to fix it and how can I repair it?
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    You will have burnt someting inside the modem.
    It was rated for 9 Volts and you applied 12 Volts, so over voltage might lead to over current and burning stuff.
    Bertus
    rezamoezzi likes this.
  3. JohnInTX
    Jun 26, 2012
    2,393
    1,051
    The adapters may also have had different polarities - zap!
  4. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    If you have a multimeter, check the voltage on the 12V adapter. Is it really 12 volts? Maybe it was an old unregulated type, and due to the light load, had a much higher voltage.
    As to what happened, was the sound like something popping? What did it sound like? Was there a smell, especially a burning smell? Open the modem, looking especially for burned components or bulging / leaking capacitors. Post a picture here, if you can. The most reliable thing to do would be to simply get a new modem rather than trust one that has been exposed to overvoltage, but I'm assuming you're interested in what happened.
  5. Alec_t
    Sep 17, 2013
    5,967
    1,135
    Any resistive component receiving 12V instead of 9V would generate 78% more heat than it was designed to! Not surprising if something fried :(.
  6. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    No one can tell you exactly what happened or how to repair it.
    Chalk it up to experience. Buy a new one and pay more attention to details in the future.
  7. ian field
    Oct 27, 2012
    4,447
    791
    Wouldn't have worked for a while if that happened.
    Most modems I've ripped for parts, had at least 3 SMPS regulators for on board rails - some are buck with series control transistor/MOSFET, if they fail short circuit; the unregulated juice hits the logic supply rails and its game over.
