MaxHeadRoom
- Joined Jul 18, 2013
- 28,619
Of course, you would be right, with no capacitor present.Are you sure?
Max.
Only if you include a reservoir electrolytic - but that would be even worse as it charged up to the peak voltage (about 320V in the case of 230V mains) otherwise you still get zero crossing (of sorts).You would loose the variable speed via the triac.
Max.
That was the correction I intended, IOW adding a cap would prevent the phase angle control.Only if you include a reservoir electrolytic - but that would be even worse as it charged up to the peak voltage (about 320V in the case of 230V mains) otherwise you still get zero crossing (of sorts).
by Duane Benson
by Jake Hertz
by Aaron Carman
