User menu structure help needed
Discussion in 'Embedded Systems and Microcontrollers' started by raidermanz, Nov 20, 2007.
  1. raidermanz
    Thread Starter Active Member
    Aug 14, 2007
    32
    Everyone in this forum has been very helpful to me in the past, so I humbly post another dilemma.
    I need to create a user interface menu for my recent application. I am using a 5 button configuration as the only interface available to the user. I have 2 primary functions which require increment/decrement capabilities with a one touch press therefore, my functions are as follows:
    button 1 Function 1 UP
    button 2 Function 1 Down
    button 3 Function 2 UP
    button 4 Function 2 Down
    button 5 Enter/Menu
    The problem is that I have 2 levels of menus which can be accessed. I can use a momentary button press of button 5 to enter one menu, and a 2 button combination press to enter the other menu. My question is what is the best way to structure the multiple "if" statements, or should I use something else like switch statements, or some other process. I am relatively new to this stuff, and I am only fluent in my CCS pic C compiler language. If anyone has any insight into an easier way to structure a menu with approximately 5 different user-selectable options on 2 different menu levels without drowning me in if statements, I would be grateful to hear from you.
    Thanks for the help.
  2. raidermanz
    Aug 14, 2007
    32
    Nobody has any suggestions on structuring a multi-level user menu to work with a pic microcontroller?
    Please...I am in real need of any suggestions.
    Thanks,
