I work for a software company, yes. What you're trying to do has 2 parts; the windows GUI part, and the micro controller part. My advice is to learn them both separately before trying to put them together. Especially if you're new to programming in general. Google is your friend. stackoverflow.com, msdn.microsoft.com, places like these will help you. And I just stumbled on the link for Visual Studio 2015:Do you work own in Software Company.?
Visual basic 2008Downloading what?
Is it is used in commercial product i mean not for teaching.?Arduino is a great platform to learn on
Arduino boards are used both for learning and in commercial products. High volume products will typically make their own circuit boards and may use the same Atmel processors that arduino boards use.Is it is used in commercial product i mean not for teaching.?
In which commercial products?Arduino boards are used both for learning and in commercial products. High volume products will typically make their own circuit boards and may use the same Atmel processors that arduino boards use.
then what is advantage of spending more than Rs1500/.I don't even think the Arduino should be used for teaching,
My recommendation would actually be to buy the AVR itself (http://www.digikey.com/product-detail/en/ATMEGA328P-PU/ATMEGA328P-PU-ND/1914589?WT.srch=1, $3.70 or Rs 246.62, and a cheap programmer (https://www.sparkfun.com/products/9825, $14.95 or Rs 996.49). Total cost: $18.65, or Rs 1243.11.then what is advantage of spending more than Rs1500/.
No, the PIC is fine. My point was that if you're set on using the Atmega128/328 AVR used in the Arduino, especially for commercial purposes, just buy the chip itself and a programmer.anyway right now i use pic should i shift from that?
You have GOT to be kidding me.....why dollar and rupees are different rates?
https://en.wikipedia.org/wiki/Exchange_ratewhy dollar and rupees are different rates?
This reminds me of talking to the old C/C++ programmers when C# was gaining popularity. "it's not a real language", "low level languages are better", etc... They didn't understand that sometimes higher level solutions are better, and this is similar.No, the PIC is fine. My point was that if you're set on using the Atmega128/328 AVR used in the Arduino, especially for commercial purposes, just buy the chip itself and a programmer.
I disagree. I have seen students in one of the labs I assisted in get completely lost with microcontrollers because all they'd done in the past was with the Arduino, which uses a butchered form of C (or rather, C++) to program it. They never learned how the micro worked, which made learning a different language even more difficult than if they'd started with a language such as Assembly or C. Learning on an Arduino takes the student a step backwards rather than forwards, and makes learning that much more difficult.This reminds me of talking to the old C/C++ programmers when C# was gaining popularity. "it's not a real language", "low level languages are better", etc... They didn't understand that sometimes higher level solutions are better, and this is similar.
My opinion on the arduino differs, especially for beginners and low budgets. Some of the arduino's are basically breakout boards for atmel processors with a USB/Serial bridge chip on board for convenience. They come pre-programmed with a beginner friendly boot loader that works nicely with their C compiler, but you're free to erase it and use your own. Use your own compiler, your own programmer, write your own libraries, write your own assembly if you want. The arduino platform is fantastic for beginners (especially beginners with limited or no hardware experience) because they are simple and the cost to get stated is very low. The arduino programming environment is good enough for beginners, there's a ton of libraries, and should you want to forgo the beginner stuff and get more advanced you can at any time. When you're ready to take your programming up a notch, Atmel Studio slips right into Visual Studio to give you a pro level compiler and IDE: http://www.atmel.com/tools/ATMELSTUDIO.aspx .
Not every project requires,or has the budget for, custom hardware. The arduino is a fantastic off the shelf micro controller solution for beginners, prototypes and low volume products.
The Arduino IDE uses avr-gcc as its compiler, so it's the same C.I disagree. I have seen students in one of the labs I assisted in get completely lost with microcontrollers because all they'd done in the past was with the Arduino, which uses a butchered form of C (or rather, C++) to program it. They never learned how the micro worked, which made learning a different language even more difficult than if they'd started with a language such as Assembly or C. Learning on an Arduino takes the student a step backwards rather than forwards, and makes learning that much more difficult.
If the goal is to learn about uControllers at the lower level, then just zap the default arduino bootloader. Then you'll essentially be left with a chip on a nice breakout board. Code for it in Atmel Studio and write to it with a programmer. There's nothing wrong with the arduino as a learning tool, that student just didn't try to learn about micro controllers.I disagree. I have seen students in one of the labs I assisted in get completely lost with microcontrollers because all they'd done in the past was with the Arduino, which uses a butchered form of C (or rather, C++) to program it. They never learned how the micro worked, which made learning a different language even more difficult than if they'd started with a language such as Assembly or C. Learning on an Arduino takes the student a step backwards rather than forwards, and makes learning that much more difficult.
It wasn't just one student, it was an entire class. And I'm pretty sure I made that point already--My problem is with the IDE. Otherwise it's just an AVR with a dev board, which is not a problem. My point is that a microcontrollers class should not teach using the Arduino IDE, as it does the exact opposite of teaching how Micros work.If the goal is to learn about uControllers at the lower level, then just zap the default arduino bootloader. Then you'll essentially be left with a chip on a nice breakout board. Code for it in Atmel Studio and write to it with a programmer. There's nothing wrong with the arduino as a learning tool, that student just didn't try to learn about micro controllers.
by Jeff Child
by Jake Hertz
by Aaron Carman
by Aaron Carman
