User a Pot to read Deg of rotation.
Discussion in 'General Electronics Chat' started by mazur50, Jun 7, 2007.
  1. mazur50
    Feb 5, 2007
    28
    I am looking for a circuit. that when i turn a pot it will tell me how many deg of rotaion i have turned. thanks.
    Mike
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    Pots are not very reliable for that. You can use rotation sensors for that.
  3. mazur50
    Feb 5, 2007
    28
    Would you have anytip to lead me in that direction of the rotation sensor and a circuit.
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    I will see.
  5. Tube Tech
    Jan 11, 2007
    46
    2 paths to rotation sensing:
    gear wheel and a hall effect sensor. limited resolution.
    optical marks and optical sensing. as much resolution as you can afford.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Or you can find a servo pot with no stop.
  7. mazur50
    Feb 5, 2007
    28
    I only need like 90 of sencing. I am tring to make a device so i can tell howmuch timming a armature has with out using a protractor.
  8. lightingman
    Apr 19, 2007
    374
    22
    Hi....The most acurate way is to use an optical shaft encoder..... These are quite expensive, but I have bought some on e-bay before at around 20 GBP.You would need a counter to count the pulses, and if you need to detect direction, a JK flip-flop.....Daniel.
  9. cumesoftware
    Apr 27, 2007
    1,330
    11
    I think that was the answer I was looking for.
  10. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  11. mazur50
    Feb 5, 2007
    28
    does anyone know where to get servo pots i have been looking but cant find them
  12. mazur50
    Feb 5, 2007
    28
  13. cumesoftware
    Apr 27, 2007
    1,330
    11
    For the first three, yes.
  14. mazur50
    Feb 5, 2007
    28
    Yes to what question.
  15. cumesoftware
    Apr 27, 2007
    1,330
    11
    Yes, for the first two options (first three links) described above, you might need a microcontroller. For the last one, maybe, maybe not.
  16. kender
    Jan 17, 2007
    263
    The circuit is very simple: connect the bottom of the pot to the power supply, bottom to ground. You will get a retiomatric sensor i.e. the ration of the voltage on the wiper to the power supply voltage will be proportional to the angle. Your problem is more mechanical rather than electrical: how are you going to secure the pot to the moving parts?
  17. Uman
    Member
    May 2, 2004
    11
    Typically a precision pot is used when angles are less than 270 degrees and angle encoders when greater than 270 degrees. Precision pot are much cheaper than encoders and less components involved.
    We have used precision pots for turrent steering position feedback on large vehicles with indepentent turrent bogies quite successfully.
