Converts graphics file (in English) to the text file (in English), docx, xlsx, txt three files.
This is a free online software, there are more convenient if you have write the program frequently, when you have a program on the book, but don't have the txt file then you can take a photo and converts the file to the text file.
You have docx, xlsx, txt file format to choose from, a total of 46 countries for conversion options, the maximum file size is 5MB, the best content of file is black and white or single color is better, otherwise it may cause an error when recognize or unrecognized.
Convert scanned pdf or jpg, gif, bmp, etc to word or .txt.
I did a simple test as follows:
1. The original photo uploaded and conversion as below:
And I got the code as:
#i nc ude <std I i b. h> void Main( void )
void *mbuf ; bit FgNULL;
mbuf = ma( I oc(1000);
i f (mbuf —NULL) FgNULL=0; else
f ree(mbuf ); FgNULL=1;
2. Cut the original photo with paint and other image software to adjust the black color getting deeper, and make the background more white, then converted to a monochrome bmp, after that you can converts bmp to gif file to make the file smaller, and then uploaded to the website to do the conversion.
3. After the format modification, I found out above all the texts conversion are complete correct, but the format of program was wrong, and two symbols "{", "}" were also wrong, the correct program as below:
Code:
#include <stdlib.h>
void Main( void )
void *mbuf;
bit FgNULL;
mbuf = malloc(1000);
if (mbuf==NULL) FgNULL=0; else 1
free(mbuf); FgNULL=1;
Code:
#include <stdlib.h>
void Main( void )
void *mbuf;
bit FgNULL;
if (mbuf==NULL)
FgNULL=0;
else
free(mbuf);
FgNULL=1;
