Used Small Variacs
Discussion in 'General Electronics Chat' started by james211, Jan 31, 2014.
  1. james211
    May 29, 2012
    210
    I live in NYC and I'm looking for a used, panel mount, small variac with an input of 120v and output of 120-132v 2 or 3amps. Does anyone know where I can find a used one? Smaller the better...
    I looked on ebay, but most of them look quite old or vintage...maybe I'm wrong and thats just the way they look.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Unless some windings are burned, used ones should be ok.
  3. inwo
    Nov 7, 2013
    2,435
    315
    I have a box of them someplace.
    I'll look to see if any are ok after storage.
    And if I can find them.:)
  4. inwo
    Nov 7, 2013
    2,435
    315
    They suffered some over the years.:(
    However, I believe at least one may be serviceable,. Maybe two.
    1.75 amps. Less than 3" diameter.
    3 variacs X 3 @ $0.00 = $0.00 plus S&H
    If you need good condition or for critical application, better pass this up, and maybe someone else wants them to play.
    On the other hand if it works for you, I always appreciate a tip. :D
    2.5 lb each from 55941 USPS
    ps.
    A larger one.
    http://forum.allaboutcircuits.com/showthread.php?p=692160#post692160
    DerStrom8 likes this.
