Used Power Benchtop Supply
Discussion in 'Electronics Resources' started by gatoruss, Dec 16, 2009.
  1. gatoruss
    Dec 14, 2009
    I am interested in buying a used benchtop power supply. I am a newbie, just starting out with simple circuits. I want to play around with programing some AVR mcu's and moving on toward building some simple robots. Folks have recommended looking on eBay, craigslist etc.
    I read some stuff on building you own (not that I am ready to do that), most of which was chock full of warnings and disclaimers telling you how you were hooking up to mains and could electrocute yourself if you didn't know what you were doing! Well, how does one confirm that a used one (or , I guess new one, for that matter) isn't faulty? My question is, how do I make sure that a used unit is safe?
    Also, what about this unit - http://www.circuitspecialists.com/prod.itml/icOid/8238 ?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. BMorse
    Sep 26, 2009
    2,675
    234
    or you can get a Computer power supply, ATX one would work, has +12,+5,+3.3, -12, -5 outputs, no need to make your own.....
    My .02
  4. bluebrakes
    Oct 17, 2009
    245
    7
  5. gatoruss
    Dec 14, 2009
    Bill, I had read your article, and found it very interesting.
    I have been toying with the notion of connecting a wall wart directly into my bread board since reading these tutorials on SparkFun Electronics and Instructables. But your idea takes it much further, making more a elaborate psu...I really like it! :)
    I know that you say the wall warts are safe...and when I asked about the SparksFun or Instructable ideas on other forums the general response has always been that they are safe. But there has always been a one or two naysayers that suggest it might be dangerous - that wall warts may not be isolated, etc. That has made me nervous.
    That is what kind of got me thinking about the question in my original post - - how do you know a used (or new for that matter) psu or wall wart is safe? Made correctly and/or not damages?
    Thanks, bluebrakes...but with shipping that is > $250US...more than I can spend for used equipment.:(
  6. retched
    Dec 5, 2009
    5,201
    313
    The only way to *truly* know about what is inside a wallwart, is to open it up. But most of the time, if what you read on you meter matches what is says on the wart, you have a unit that is good to go.
    If the wart says 12v and your reading 18v on your meter, don't use it. Better yet, dissect it for usable parts. Old equipment is a good source for filling your parts bins.
  7. gatoruss
    Dec 14, 2009
    I understood that unregulated wall warts would show a high voltage if read without a load. That seemed to a consistent point in much of the research that I have done. For example, see this from Bill's article (linked above):
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Uh, no. All it means is you don't have the Wall Wart loaded to it's rated current. This is normal behavior for a unregulated power supply, which happens to be a wall wart in this case.
    You really don't have to know what is inside, it is a black box after all. The whole point of using one is safety, which is not what opening one would be.
  9. Waifian
    Jan 26, 2010
    You should make your own variable power supply from a Wallwart and a few resistors an a pot, filter capacitors, an LM317 regulator and perhaps diodes if the wallwart output is not rectified already. The datasheet for the LM317 has a lot of information on basic setups. You can get outputs from about 1.2 volts up to about 35 volts I think. With a heat sink attached you should be able to supply about 1 amp depending on the current rating of the wallwart. This is a very good simple project.
    One of my first projects. I still use it. Super cheap. You do need a meter to set the output.
  10. maxpower097
    Feb 20, 2009
    795
    388
