Used li ion cells...
Externet
Joined Nov 29, 2005
2,219
What circuit to build to evaluate 18650 cells ?
Lithium cells salvaged from used battery packs do have an use in hobbies and general applications.
As some cells may be weak, I would like to build a circuit to evaluate their health state.
For a given -say 2.0 Amperehour- rated cell, what load resistor value should be convenient to use for how long and measuring what curve of voltage drop during the discharge test in order to qualify the cell as 'good' or 'useable' or 'bad' ?
(+)---------------V(+)-----------------R
Cell
under
test
(-)----------------V(-)------------------R
[ Voltmeter connected at V; resistor connected at R ]
wayneh
Joined Sep 9, 2010
17,498
You said the magic word, "arbitrary". The suitability of a cell depends on the application you want to use it for. If you can, use a test and a hurdle that relate closely to the intended use. Anything else leads to mistakes, where the test said it was a good cell, but it fails in the real world application.
Another method might be to estimate the percent of a cell's expected life that remains. You might then choose to toss out any that fall below, say, 10%. You don't want to keep wasting time on the same bad cells.
