Use strain gauges from a digital scale
Discussion in 'The Projects Forum' started by ant.g, Mar 31, 2010.
  1. ant.g
    Mar 31, 2010
    New to this. Need to measure weight in a box for a project. Can't use a scale in traditional sense so I recently removed the strain gauges from a digital scale. I am trying record voltages from the gauges. I have read other post that the gauges have two outputs and you should not connect anything to ground; as this could fry the gauges. How to I collect data from devices, and once data is collect how do I use it to as the scale did?
  2. retched
    Dec 5, 2009
    5,201
    313
    You will need an op-amp to boost the signal from the gauge. That will give you a more measurable voltage. You then 'calibrate' the gauge with a known weight and you can do the math to figure on changes in voltage to weight ratios.
    ant.g likes this.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    ant.g likes this.
