use SimVision commands with Perl
Discussion in 'Programmer's Corner' started by dm_manu, Aug 3, 2006.
  1. dm_manu
    Aug 3, 2006
    bonjour
    j'ai compiler et simuer les codes vhdl a partir de logiciel SimVision Cadence avec les commandes (ncvhdl, ncsim...)
    est ce que je peux lancer ces commandes a partir du langage Perl sans utiliser la console du SimVion?
  2. dm_manu
    Aug 3, 2006
    pour simuler un code vhdl sur la console du SimVision j'ecris selemment:
    ncsim e:/work/fichier.vhd
    mais comment je peut faire a partir de la console de Perl sans utiliser la console du SimVision.
    j'ai deja fais avec la methode sur Perl:
    system "ncsim e:/work/fichier.vhd"
    exec "ncsim e:/work/fichier.vhd"
    mais ne marche pas
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    En Franglais
    La lange de cette forum est Anglais.
    Comprennez vous?
  4. dm_manu
    Aug 3, 2006
    hello
    can I use perl to execute the comand of simvion for simulate vhdl without using
    command windows of simvision?
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Literally translated:
    Hello, I have to compile and simulate the codes vhdl from software SimVision Cadence with the orders (ncvhdl, ncsim...). Can I launch these orders from language Perl without using the console of SimVision?
    Dave
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    To simulate a vhdl code on the console of SimVision I select: ncsim "e:/work/fichier.vhd", but how I can make it do this from the Perl cosole without using the console of SimVision. I have already made a method on Perl: system "ncsim e:/work/fichier.vhd" exec "ncsim e:/work/fichier.vhd", but it does not work.
    Being unfamiliar with both SimVision and Perl I'm not sure if my translation makes any sense, but its a start.
    EDITED: I have merged the French and English threads into one.
    Dave
