Can you use supercapacitor, say 48 V and 165 F, while it is being charged? Can you use the supercapacitor for a much longer or longer duration, or ""infinitely"" if the charging time is a bit faster than the consumption of its energy? Thank you!
Yes. The capacitor will respond to the net current flow, charging if IN > OUT, discharging if OUT > IN. Once charged or discharged, IN and OUT must be equal since no more charge can go in or out, respectively.Can you use supercapacitor, say 48 V and 165 F, while it is being charged? Can you use the supercapacitor for a much longer or longer duration, or ""infinitely"" if the charging time is a bit faster than the consumption of its energy? Thank you!
by Jake Hertz
by Jake Hertz
by Jake Hertz
