Hi all,
I'm trying to get to grips with this VHDL language. As part of that I'm following some exercises, one of which asks me to write some VHDL code to perform a 4-bit shift register operation (serial in, parallel out).
So, I had a very obvious idea in mind for this that I knew would work, but I decided to do some googling to see if there were any better solutions that I could try. I found reference to the use of the concatenation operator for shift register operation. It goes something like this:
I tried this technique in my own program (in fact the above is my own use of the technique) and it works. The only question I have now is; why does it work?!
I understand that concatenation is the act of joining two variables together. I have experience of this with strings in the C language.
So, I understand how a bit on the Serial_In can be added on to the 4-bit Parallel_Out signal. What I don't understand, is how the shifting works. I can see that it has something to do with operating on the Parallel_Out signal using "3 downto 1" instead of "3 downto 0", so the right-most bit is not part of the concatenation, but I can't quite grasp why this means it would be shifted?
Can anyone advise?
Thanks very much,
Brian
Rich (BB code):
elsif (Man_Clock'event and Man_Clock = '1') then -- rising edge triggered
Parallel_Out <= Serial_In & Parallel_Out (3 downto 1);
Can anyone advise?
Thanks very much,
Brian
