Use of 3914
Discussion in 'General Electronics Chat' started by devgorkha, May 2, 2011.
  1. devgorkha
    May 17, 2010
    29
    can i use LM 3914 as led bar graph display for audio source ? pls ... suggest me related circuit
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. shortbus
    Sep 30, 2009
    4,096
    1,690
  4. marshallf3
    Jul 26, 2010
    2,358
    201
    If you go directly to the http://www.national.com website and enter LM3914 (or 15 or 16) into the search box you'll get access to the full data sheet that has tons of info in it as well as a lot of application notes that illustrate the many ways the IC can be used.
  5. KJ6EAD
    Apr 30, 2011
    1,426
    364
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you want a single 10-LED bar graph, then use the LM3916 VU meter IC.
    If you want more than 10 LEDs, use the LM3915 logarithmic IC's.
    The LM3914 will not work well for music, as humans basically hear in decibels, which is much closer to a logarithmic scale than a linear scale.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    No.
    If you want the different spacings of an LM3916 VU meter then use only one.
    If you want logarithmic equal spacings and/or want to cascade them then use logarithmic LM3915s.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Thanks A.G.; I was distracted while making that post. I've corrected the part numbers in my post.
