Use battery’s own power to recharge itself for continual energy
Discussion in 'Off-Topic' started by ptownbro, Sep 29, 2013.
Thread Status:
Not open for further replies.
  1. ptownbro
    Sep 28, 2013
    17
    I know this cannot be done, but couldn't (ashamed to say) convincingly explain this to a friend why it can't using realistic values.
    Can anyone explain why I cannot use the power produced by a battery to loop back and power that same battery to have continual power? Explain it using numbers/math and some common units of measures (e.g. volts, amps, ohms, power...)?
    Here's an example. Why wouldn't this work to have continual power?
    You have a 12V car battery which is connected to a motor. Then, you use that motor to turn an alternator which in turn recharges the original 12V car battery (similar to how a car works).
    Car Battery ---> Motor ==> Alternator ---> Car Battery (loop back to original car battery)... repeat...
    Now, I know the common replies will state you lose power along the way through heat, friction, etc... so you don't have enough power to loop back to the battery to keep charging it. As such, eventually you'll run out of power.
    How can you prove this using my basic model above with electrical measures, math, or numbers using a more realistic example of measures like volts, amps, ohms, watts, etc...?
    I tried this but need real measures:
    The battery has 100 units of power, which it transfers the motor. The motor then takes that 100 units of power, but only transfers 90 units to the alternator (10 units of power are lost from heat, friction, etc..). Last, the alternator then gives only 70 units back to the original battery (loses 10 unis like the motor).... Process starts again with 80. As you can see you keep repeating this, eventually you'll run out of power.
    Now how can I do this with more realistic measures and math?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    PackratKing and Sensacell like this.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    As mentioned, this is a closed topic at AAC.
    The second law of thermodynamics pretty much covers it.
    Nothing converts with 100%, that in itself is impossible. Little losses add up.
Thread Status:
