Hello everyone!
I know you can't buy Americium at a local Radioshack or Photobeam lasers at our local goodwill or Fry's Electronics stores, but I was thinking after I finish my project here is to maybe work on my own hybrid fire detector as a little experiment that would use temperature and smoke to determine if there is a fire. I know there is a part you can get that acts like a temperature resistor. Something the lines of RTD if I'm correct.
But anyways my main question is, where do I buy this sort of stuff such as Americium device or a photobeam laser and also the "RTD" (if I'm correct)? And are photobeams better then Americium?
I was impressed the fact they use Photobeams in some advanced small smoke detectors and use photobeams in 2 way smoke detectors that are aligned with each other over high places so they don't spend the money and time installing more small smoke detectors.
Anyways correct me if I'm wrong on if it's not photobeam, but I'm kinda basing this off of memory so it could be another type of laser.
Thank you, Ajm113.
Thank you, Ajm113.
