Use a microphone to detect specific sound plus a motion sensor and arduino
Discussion in 'Homework Help' started by mcamiea, Jun 17, 2016.
  1. mcamiea
    Feb 19, 2016
    5
    Hi guys, I would greatly appreciate your help, I have a different background than electronics and programming, so I am completely lost and in desperately need of help, so any little help can save me. I want to do a project to for saving water in the shower to one of my university courses. The idea is to have a motion sensor and a microphone connected to and Arduino Uno, so when the sensor sense movement in the shower (when the person gets in) and when the mic "senses" the shower noise activates a timer. What I want to do next is just give a sound signal when a time is reached. For now I just want to know if the microphone part is possible, I have seen some projects that detects sound, but I don't know if an specific sound like the shower noise can be detected, Also I am not sure which microphone will be best for this, I read and I will probably need and Electrec plus an amplifier, but honestly I don't know this topic, so I am not sure, If there is someone that knows if this is possible and how it can be possible it will be great and as I said lifesaver, thanks a lot and excuse my huge ignorance.
  2. dannyf
    Sep 13, 2015
    2,196
    417
    why don't you just experiment?
    The key I think will be what you meant by "specific". The answer ranges from "sure" to "impossible", depending on your answer there.
    The simplest solution would be to have a human sound detector: hire a guy standing there and if he hears the right command, he will activate the water.
  3. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Any of the following could be fitted to the shower head to indicate when it is probably in use:
    • flow sensor
    • pressure switch
    • piezo transducer to "listen" for the flowing water
    • temperature sensor
    • A pair of probes to detect the presence of water by measuring its resistance
    I don't know why you need to know when someone gets in the shower.
  4. Sensacell
    Jun 19, 2012
    1,184
    277
    This sensing idea is rather tricky and not very reliable- how does it differentiate a voice from water flowing?
    Maybe with some sophisticated spectral analysis? but that's not easy, nor foolproof.
  5. mcamiea
    Feb 19, 2016
    5
    thanks for the replies, what I wanted at the beginning was to detect the sound of the running water, I thought of it that way because I want to know automatically the moment when the person is taking a shower. I thought of the microphone ecause maybe not all the shower heads are suitable to put a sensor, but I have researched it and as you all say my idea may seem too difficult, so I will probably go for another way to detect the running water, Thanks for the advice, I will have to change my concept idea, probably use a pressure switch.
