Use a JK flip flop to implement a SR flip flop
Discussion in 'Homework Help' started by Karamelg1, Apr 25, 2007.
  1. Karamelg1
    Mar 25, 2007
    12
    I am instructed to implement a SR flip flop from a JK flip flop. I was wondering if it was as simple as just hooking up an S input into the J part of the ff, and a R input into the K input? My professor has the solution equation as J=S and K=R, but I am trying to actually draw the diagram. Any help would be appreciated. Thanks!
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    As you know the SR flip-flop is typically not clocked. It is asyncronous. A JK on the other hand has four syncronous input possibilities: set, clear, toggle and hold. In order to determine the next state you must specify both J AND K. In my opinion it is not sufficient to sepcify J=S and K is a don't care for the set function.
    Some JK flip-flops have asyncronous preset and clear inputs which only serves to obscure the issues.
  3. recca02
    Apr 2, 2007
    1,211
    try reading abt k-map, there might also be solved examples using k map to convert J K to S R in a book dealing with k map, i have done this before but do not remember it.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I do not think a karnaugh map will be of any use here. They are for minimization AFTER you have a boolean equation. They are useless before you have one.
  5. recca02
    Apr 2, 2007
    1,211
    i m not as experienced as you mr P.B.,
    but i do remember solving this kind of problems using k map.
    in which the inputs come out as a combination of previous state and s and r inputs.
    also sometimes the conversion does seem illogical as might happen in case of J K
    to S R conversion.
    but for other conversions like s r to j k or d to t
    it does make some sense.
    i wud have liked to show you the example i solved but due to some reasons(MY exams) i can not solve it right now as i will also have to brush up on the concept. may be on jun 20 i wud be in a position to do so if required.
  6. Karamelg1
    Mar 25, 2007
    12
    Thanks for your help. It is completely confusing to me ~ My final exam is tomorrow, so I guess I shall just keep my fingers crossed :eek:
