Use 1/2W resistors in place of 1W?
Discussion in 'General Electronics Chat' started by Mossen, May 30, 2011.
  1. Mossen
    Dec 21, 2010
    16
    Hello
    I'm building a circuit that calls for a 1W resistor. But I only have 1/2 W available. Can I use 2 of those to do the job as long as the resistance calculates to the same value?
    Mossen
  2. tom66
    May 9, 2009
    2,613
    214
    Yes. Resistors in series add, resistors in parallel (for the same value) divide the resistance by the number of resistors.
  3. k7elp60
    Nov 4, 2008
    478
    69
    To add what Tom66 said. The wattage always increases when resistors are connected in series or parallel. All you have to do is add the wattage together.
  4. Mossen
    Dec 21, 2010
    16
    Just for discussion's sake, is this true even when the resistors used are not the same value? In the example above, if one of them is dropping a much larger voltage, wouldn't it also be dissipating more than its rated wattage?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Power dissipated by a resistor is the product of the voltage across it and the current through it. If you have resistors in parallel, one resistor can't have a larger voltage drop than the other, only a greater current depending on its value.
  6. #12
    Nov 30, 2010
    16,665
    7,313
    A one watt resistor is capable of dissipating one watt of heat without being damaged, if the external air is about room temperature, nearby parts dont heat it by conduction, things like that.
  7. Jaguarjoe
    Apr 7, 2010
    770
    90
    It is always good to derate a resistor's wattage by at least a factor of 2. 2-1/2 is even better.
    A 1 watt resistor dissipating 1 watt will get very warm. For some it can get up to 200 degrees F.
  8. Kingsparks
    Member
    May 17, 2011
    118
    5
    To the question of one resistor running hotter then the other if the values are different.
    Take a 12V supply, two resistors in parallel, a 10 ohm and a 100 ohm.
    They both drop 12V. The 10 ohm draws 1200mA or 1.2A. The 100 ohm draws 120mA or .12A.
    I*V=Power so the 10 ohm is dissipating; 12*1.2=14.4W The 100 ohm is dissipating; 12*.12=1.44W
    So, yes, the value makes a difference, depends on the resistor as to if it exceeds the rating.
