Hello all!
Is it possible to use a Centronics connector (http://en.wikipedia.org/wiki/Micro_ribbon) to pass data/power between 2 devices that are using a USB3 or SATA3 interface? I am creating a dock for a project of mine and I was looking for a rugged connector that can handle repeated connection/disconnection. The external device will be have either a USB3 or SATA interface originally.
1: SATA: Would be the easiest and, I think, most compatible
2: USB3 uses a 20pin(technically 19 pin) header on my mobo that supports 2 USB A type ports. That is supposed to be 9 pins per port and an ID pin. I've looked for information on what the ID pin does but I have not found anything conclusive information.
Theoretically as long as I make sure the right wires go to the right pins and they match on both sides it should all work, I am just unsure if the connector is compatible enough to provide power and data.
Please let me know what you think and any suggestions are much appreciated.
Terrence
Edited to make correction
Terrence
