USB to Serial RS232 cable problems
Discussion in 'General Electronics Chat' started by Chaabane, Feb 26, 2010.
  1. Chaabane
    Nov 30, 2009
    37
    i have this cable that convert USB to RS232 (i guess).but when i plug it in my laptop,it ask for driver. and i didn't get any CD with it. ??
    i want to use it with my pic boot-loader. so i can program from my laptop without the need to go to my PC.
    Any idea about this problem ???
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Yes you need a driver. I suggest you Google the manufactures name and/or model name. I am sure they have web site for driver download
  3. Chaabane
    Nov 30, 2009
    37
    Hi
    the problem is that i don't have the manufacture name, and i downloaded lots of driver,but no one works
  4. BMorse
    Sep 26, 2009
    2,675
    234
    when you plug it into the computer, it should have displayed a device name or something such as example :
    do you remember what it said the device was?
    B. Morse
  5. retched
    Dec 5, 2009
    5,201
    313
    What type of boot loader / programmer do you have? Is it a velleman?
    If the driver installs properly, but the PIC doesn't program, it is usually because USB doesn't have the 12v that some programmers need to write the PIC. The usb rs-232 driver is an rs-232 emulator, used for proper communications at logic levels, however you need the 12v rail from 'real' rs-232 to program on programmers that donot have their own 12v source.
  6. spinnaker
    Oct 29, 2009
    5,074
    1,176
    I have a RS232 version of these a a parallel version. Neither required a driver for Windows XP.
    What OS are you using?
    Did you write the boot loader or buy it?
    It might be that the software is not compatible. I sell a software product of my own and I had complaints that it does not work with one of these RS232 USB ports but I have been unable to duplicate the problem.
  7. t06afre
    May 11, 2009
    5,939
    1,222
    Why not get a PICKIT or a PICKIT clone. They work and do not set you more back than a USB to RS232 converter.
  8. kubeek
    Sep 20, 2005
    4,688
    806
    Or and FT232R chip from FTDI, which saves you the hassle of converting the +/-12V RS232 levels back to 0-5V logic. Very easy to use, but it is SMD which could be a problem if you don´t have the necessary tools and precision.
  9. Razor Concepts
    Oct 7, 2008
    212
  10. Chaabane
    Nov 30, 2009
    37
    Thanks guys for all your comments,I really appreciate it.
    yeah,it gives me this message ""USB2.0-Ser!" just this message.
    i didn't try the pic yet.should I ?
    i didn't even try the bootloader,i'll try to program the pic with it.
    I'm in Algeria dude, this PICKITs doesn't exist here, and it will took lots time to get one.
    hmmm,i'm not sure about but i'll check it,Thanks
    Thanks,i'll check it
  11. t06afre
    May 11, 2009
    5,939
    1,222
  12. lkwah86
    Member
    Mar 9, 2007
    22
    Can Windows 7 compatible with the USB to parallel converter? any driver for this?
  13. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    JDM and other simple programmers need true RS232 ports, the emulated USB to RS232 do not work.
