Thanks PapabravoUSB has 4 pins, 2 Power pins and 2 Data pins. RJ45 has 8 pins, usually 4 twisted pairs. You don't need any circuitry, just connect the pins the way you want. Now you have USB on RJ45 for what purpose?
I hope you were not asking for a USB to Ethernet conversion, that would be a much taller order.
http://www.dx.com/p/usb-cable-via-rj45-extender-set-pair-123484#.VEfRnqR0yM8- Color: Black
- Plastic case material
- Allows you to connect your USB device to your computer at a distance of up to 50m with the help of RJ45 cable
- No external power needed
- USB 2.0/1.1 compatible
- Hot swappable
good luck. I'm out of this thread.I need it to connect the internet dongle to laptop using cat5e
by Aaron Carman
by Aaron Carman
by Duane Benson
by Jake Hertz
