Usb To Midi
Discussion in 'General Electronics Chat' started by vineo763, Aug 13, 2006.
  1. vineo763
    Aug 13, 2006
    12
    Does anyone knoe how to test a USB TO MIDI CABLE?
  2. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Load the drivers, plug it in..... see if the computer recognises it.... load up you midi software..(Cakewalk or whatever)... see if it is recognised by the software..... hook the cable up to a MIDI module... output a track to the usb midi port via your software..... Is it working..????
  3. vineo763
    Aug 13, 2006
    12
    I wanted to know if there was a way that I can test it without using a computer. Can I test it with a multimeter?
  4. Gadget
    Jan 10, 2006
    613
    No. It will require a valid USB signal, addressing it correctly and supplying the correct data at the correct rate for it to output a valid MIDI signal.
    Unless you can see an obvious fault, then I suggest my first reply as your best course of action.
  5. vineo763
    Aug 13, 2006
    12
    Hey, I found a new article in the magazine "Nuts & Volts" that tells you how to build a USB - MIDI Tester. Thats great!
  6. Gadget
    Jan 10, 2006
    613
    Good luck with that. I use midi a LOT in my studio. Its fun and flexible. Hope you have fun with it too.
