USB projects, where do I start?
Discussion in 'Embedded Systems and Microcontrollers' started by BlackCow, Oct 28, 2010.
  1. BlackCow
    Thread Starter Active Member
    May 11, 2009
    65
    So far any projects I have worked on, that communicate to a PC, do so through RS232. I would like to use USB instead but I don't know where to start.
    Do they make a simple USB chip like they have UARTS for serial?
    I've also heard of using PIC micro-controllers to communicate via USB. I have only worked with 16Fxx series PICs, would those work?
    Thanks.
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    It's called an FT232R or if you want a PIC the 18F2550 is a popular choice.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
  4. MMcLaren
    Feb 14, 2010
    759
    116
    Another alternative: Stick with your regular PIC devices and modify a $2.68 (including shipping) Chinese clone Nokia CA-42 usb-to-serial adapter cable.
    You can't access the USB 5v signal through it but it does make a nice inexpensive interface without adding all of the USB code overhead to your projects.
    I even use it for serial USB access with bit-banged serial drivers on little 10F' and 12F' projects.
  5. BlackCow
    May 11, 2009
    65
  6. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Lots of USB analyzer software out there.
    http://www.usblyzer.com/
    Also Jan Axelson's USB complete book would be a must read.
    BlackCow likes this.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Well the expensive ones from LeCroy cost several thousands. Believe me, when you're trying to figure out why your device won't get past enumeration $400.00 is nuthin'. The software ones don't present the information in the most understandable way.
    I second the recommendation on Jan Axelson's books.
  8. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I've had good success with a MAX3421, a port sniffer, and careful monitoring of the status port.
    There are a number of USB class protocols. My suggestion would be to pick one and learn it thoroughly.
