USB powered batteries
Discussion in 'The Projects Forum' started by Siyom, Aug 11, 2012.
  1. Siyom
    Aug 9, 2012
    33
    I need to design a system that charges off a USB port,i'm using an FT232 chip and i'd like to knwo which rechargeable batteries are supported here,they have to either be 5 volts or bigger
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    You're forgetting the USB port is only 5V maximum so realistically your battery will be limited to about 4V.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Also what type of batteries. Many modern battery types are not easy to charge correct
